To do this:
I created the folder VisualSlideShowDemo in the top folder of my
louslittle web site
I created a sub folder named FW in that Demo folder - here is where I
uploaded the Freeway stuff to
I used SlideShow to create its slide show on my local computer in a
folder named Test1
I used Fetch to upload this “Test1” folder to the Demo folder
In FW I inserted an iFrame action and set the URL name to http://louslittle.com/VisualSlideShowDemo/Test1
Upload the FW stuff and you are done
To do what I did, you are going to have to leave the area where your
big picture is blank. Then, in Freeway, get/use the iFrame action to
create the iFrame where the big picture is, to display the slide show
in. You are going to have to adjust the picture sizes and Slide show
options to fit every thing together. The iFrame action is in the menu
Insert → Action Item → iFrame
