[Pro] Slideshow
Hi Paul, thanks for the reply.
I am aware of the carousel action and have used this successfully in several sites to date. I am also aware that Jquery is not compatible with some action libraries within FW.
However I want to use the examples above as they offer a greater level functionality/control of my carousel. But more than that I want to get my head around implementing this in FW so I personally have a better logical understanding of the software. Added to that I will have some cool carousels!
As you also mentioned I would like a carousel that fades into each frame when selected via buttons and using a loop effect - Weavers does not offer this depth of capability I am sad to say!
Thus if I can understand how to use these Plugins etc I can achieve my desired functionality in FW as I am very fastidious!
Here is a demo of a gallery:
http://galleria.aino.se/media/galleria/demos/dots-01.html
And these are the basic usage instructions:
I have tried to follow these but not quite there… Once again a short instruction list would be very helpful in seeing where I am going wrong!
Any help on this would be great guys!
Worm
Fantastic! Your keeping late hours, that’s my biggest problem in being a web designer, anyway have fun in Fiji. The Fiji Government is not a big fan of the Aussie Government ( Labour ) but then neither am I. ; )
Hope this makes sense? If you still have problems I can create a FW sample for you.
Kind regards,
Pete
Thanks for replying Pete,
You know I think you may be spot on with the CSS link missing!
However if you could upload a FW example when you have the time that would be great for me and everyone on here Pete!
Worm
Hi Worm,
OK, I will do it now give us 5 minutes.
Pete
Hi Worm,
Download FW file here. Account Suspended
Have a look at the HTML markup then have a look at the markup on the page.
Go to the FW folder and inside the “Site Folder” is another folder called “galleria” all your stuff is inside that folder which you will have to separately upload to your server.
Any probs, let us know.
Pete
