I was going about it a different way by inserting a html item (my slide container) then inserting my images code via the crowbar action. Then apply upload extra resources action, include the images and .js files. Then Include the jQuery and Galleria on my web page, in the Page-HTML markup!
I’m sure I can do it this way also, but your way is far simpler!
Hi Worm, Thank you for you kind words. I was in a bit of a rush last night and just checked it again. There is a small problem that may need to be fixed? Do you notice a quick loading of the script before the images load into the box on screen. It maybe on my side & since it’s not uploaded then I don’t know?, to make load quicker can you move the HTML markup a notch higher from “Before ” to “Before ”.
