[Pro] Slimbox
Hi,
I’d like to use the Slimbox effect,
but not sure where to get it, is
it part of Freeway Pro?
Bob
Hi Bob,
in Freeway this is called ScriptyLightbox and ScriptyLightbox2 available on ActionsForge.
Slimbox btw is anyway not recommended cause it is based on the mootools library which isn’t compatible to the freeway’s often used scriptaculous/prototype surrounding.
Hi Thomas,
I kinda new to Freeway,
I’ve looked around on youtube
for a tutorial but couldn’t find
one. Do you know of any?
thanks,
bob
ahmm - for what? For the lightbox? I think it’s not necessary to have a huge tut for that.
Just go to:
http://actionsforge.com/actions/view/215-scriptylightbox2
download and install the action and have a look on Walter’s demo (example).
