Hi everybody!
I have a problem with a scroll using smooth scroll page action.
In the link I posted you can see that the action works perfectly except when you clik on “Le Valette En Gipoun” (the latest button on the right of the submenu).
Is there any code wizard who can tell me what’s wrong?
Thanks a lot!
That last button has an image map associated with it, rather than a normal link. SmoothScroll does not work with image maps. Compare how you made this last link with the other three. If you used a graphic box containing text for all four, then the difference might be the accented capital letters in the fourth button. These could force the text outside of the bounds of the graphic box, and Freeway will notice that the image no longer is rectangular and automatically shift to an image map. (There is no user-level control over this behavior, you just have to realize it will happen whenever a linked object is not purely rectangular.)
A simple way to ensure that this never affects your menu is to either use HTML text for these buttons (normal text links, styled to look the way you have them here) or to export each menu button image as a separate image, and then import it within a pass-through image box and apply the link to that pass-through box. That will force Freeway to always use a normal link, rather than an image map.
On Apr 15, 2013, at 9:11 AM, ANDREA DALLA FONTANA wrote:
Hi everybody!
Thanks a lot!
