billyk
March 9, 2014, 5:58pm
1
Has anyone ever used smooth scroll with inline design or backdraft? I’m using ad selector for id’s and that works but smooth scroll does not. Maybe a conflict with backdraft mark up?
Billy
billykimmel.com
actionsdev mailing list
billyk
March 9, 2014, 6:01pm
2
Not the Backdraft mark-up. I get tit to work in Walters D’s example but not my design.
Ugh!
Billy
With inline design, as seen here in the secondary menu above the used drill
rigs - http://industrialmarketing.com.au/drillrigs.html
Depending on the way you are implementing smooth scroll, it could be
scripting conflicts with other actions or slideshows. Try disabling those
first to see if it then works.
billyk
March 9, 2014, 6:28pm
4
Yes It’s WOW Slider. Is there a work around?
Billy
billyk
March 9, 2014, 6:40pm
5
iframe will work. Must be the javascript.
WOW slider uses jQuery and Smooth Scroll uses Script/Protaculous = conflicting libraries.
Try the NoConflict action - available at the Forge.
waltd
(Walter Davis)
March 10, 2014, 1:36pm
7
I haven’t tried it in Backdraft, but I have made fully inline pages (with and without Freeway) that respond to smooth scroll perfectly.
Ugh!
Billy
Richard
(Richard)
April 9, 2014, 7:52pm
8
I just tried the SmoothScroll action v.0.5.4, but the links don’t respond (at all) for as long as the action is applied to the page.
As soon as I remove the action, the links work. I’m not sure what I am doing wrong, or if I’m doing something wrong at all.
If you can spare a minute, please have a peak at : http://fwdemo.rvanheukelum.com/smoothscroll/index.html
Richard
