perhaps, another silly thing… I cant manage with the smooth scroll action. I have a page with an anchor called anchor1 set at 1790 pixels from top. At the top of the page, a button links to this anchor. At the page, the smooth scroll action applied. The links is instantaneous, doesnt make a smooth scroll… I have tried with offset from 0 to 100, and with all the duration at the palette action, and nothing…
OK, thanks. Now it works. Actually, I was using map areas for the buttons. SO you need to make the button as a html text… And if the button needs to be a graphic, what can do? Can you write the html text over as invisible? Is it possible?
If you make sure that your button image is imported into Freeway as a square-cornered graphic (not rounded in any way, either by setting corner radius or adding a shadow in the Inspector) then Freeway will always make a normal link from it. (Always, as long as the image isn’t grouped with another graphic, which can happen if you draw one graphic over the top of another graphic.) Freeway only gets fancy and uses a map instead of a normal link when it cannot define a clear-cut graphic to place inside of the link tag, or the element isn’t rectangular.
