Does anyone know if Smooth Scroll works with FWP 6.1.2 and Backdraft 1.5?
http://actionsforge.com/actions/smoothscroll
tell me - why are you concerned?
Neither inline nor latest versions (usually) break functions.
Yep, it works. Just make sure that you don’t have any jQuery loaded into the page (like WOW Slider).
… or choose a "smooth scroll based on jQuery instead … ![]()
Very true, there are a lot of alternatives out there that are quite easy to implement.
Yeah, the problem was with WOW Slider. Caleb emailed me earlier. Is Amazing Carousel jQuery based?
Whenever you read “Scripty” in an action-name, you can be sure this is from Scriptaculous/Prototype and therefor be aware of using it together with jQuery (without no-conflict).
As far as I know there are (only) three jQuery based thing in the Freeway-world:
From Amazing Slider’s home page:
Amazing Carousel is an easy-to-use Windows & Mac app that enables you to create circular, responsive jQuery Carousel and jQuery Image Scroller.
Thank you gentlemen.
… haha, what a misunderstanding - I was under the impression to talk about “Walter’s amazing carousel”.
