Hi Walter et all …
hope you are faring well…
for some reason SmoothScroll is no longer working. Rather the link are snapping to the anchors…
will there be an update to this page action…
Thanks all
Can you show me a link to a page where it doesn’t work? I haven’t made any changes to the Action in literally years.
On Mar 2, 2021, at 3:57 PM, Carla email@hidden wrote:
Hi Walter et all …
You need to add the HTTPS Helper Action to this page, or just download and apply the newer Protaculous Action to the page. You have links to http:// for the JavaScripts, and the rest of the page is secure. You can’t have insecure scripts in a secure page.
On Mar 2, 2021, at 4:11 PM, Carla email@hidden wrote:
I applied the Https Helper to the page Walter, but is there another update action I should install… this is all because I moved over to Parallels so all available actions did not move over … what a mess
thx again
I just realized that all of my Freeway Pro Actions in Library did not move over to Parallels which caused a boatload of issues… I did copy that folder in December when I started this venture of dual OS! but it did not copy to Library
