Hi guys.
I’m planning to move my site from iWeb to freeway.
I downloaded latest trial version of freeway pro.
as you may know, iWeb has ability to snap any object to each other. when you drag something around, blue lines appear and helps you set them together.
I can’t do this with freeway pro, is there any option or plug-in for that? I really need this, either I have to manually set heigh & width to place things in a line.
On 5 Sep 2011, at 09:53, Khashayar Ebrahimi wrote:
Hi guys.
