I discovered recently that an intruder-advertisement entered my site…it is from mirando.de… see www.fritsjansen.nl/freetalk1.tiff …when I look at the sources with safari I see on the left side that they put some images and scripts code on my site, see www.fritsjansen.nl/frreetalk2.tiff but I can’t discover where it is…it seems that it is not placed on the index.html…I want to remove it…is that possible?..can somebody give me some advice…I want to get rid of that annoying stuff…regards…
I am not sure about this, but if you Republish the complete site within Freeway goto File> (press CTRL Key_ note that Publish changes to Publish Everything.
Then re upload to your hosting company won’t this overwrite your site… Of course there maybe other “Rouge” files within your site so it may be worth deleting all files from from the relevant folder within your hosting site, the applicable folder is named if you go to File>Document Setup and then in Directory should be the root folder.
I am not expert but just a thought.
John
If your ISP gives you a File Manager that lets you list the files and include a date/time column you can check for recently changed or added files. Even better if that File Manager lets you sort the list by date/time.
