I’m having trouble getting the Sound FX action to work when the trigger is set to “click”. It works fine when the trigger is setto “mouseover”. Any ideas?
Bryan
Can you post your example online.
What size/type is the sound file?
Hi David,
Here is the link - Coutureatelier.com is For Sale | BrandBucket
The mouse-over sound on the camera works but when the home or cameras buttons (these are the only two that work) are clicked, their isn’t any sound.
The settings are identical aside from the mouse-over/click. The file is a mp3 and the size is 16kb.
Bryan
Is this because as soon as the link is clicked you are taken to the other page?
Take the link off and see if it works onclick then. Sound files can’t be played across pages like this.
Thanks Dave, you’re correct. I thought that the sound would work when clicked but it doesn’t when there is a link to another page.
Bryan
