Good morning- I have redesigned a website with fwp6 and all looks good on the desktop side of life… One issue I am experiencing on the mobile side of life is that the Spawn New Windows will not scroll as they do on the desktop… Is this by design and do I have to custom size each window ??? Or, is there a setting I am missing… I have tested one spn link selecting scroll bars, but did not make a difference…
Anyone run into this before… Cheers…
http://zscapes.com/Collections/Image%20Pages/emigrantimages.html
The SNW Action creates an iframe, then disables scrolling on it with scrolling=”0”.
The Author of the action is Paul Dunning http://www.actionsworld.com/contact.php and he has an explanation of the issues with the action in iOS at http://www.actionsworld.com/Actions/SpawnNewWindow/ipadfriendly.php
Thank you David-
The link explained ti nicely… Not what i wanted to hear, but will have to decide what to do going forward… If you know, does scriptylightbox3 get around this issue ???
Cheers… Mark z
If you are thinking Responsive going forward then I suggest that you look at a totally different option altogether, ie one that allows you to choose the Next/Previous location.
