Hello there, my site has spreading page sydrome in where the pop up pages are fine, but the main pages seem to open in the browser sometimes not constrained to the size i have put into the inspector, i can tell this because if i close up the page by pulling the corner page tab, the scroll bar begins to appear at about what i consider the page width should be, how can i constrain the pages so when they display they display at the correct size in the browser ?.
Thanks James
Hi James
Most users would like to arrange the size of the browser windows themselves. I would suggest not to worry to much as long as you don’t have a long sideways scroll.
Thanks James
You don’t say if you are using Express or Pro but it sounds like an Express issue.
Can you post a link to an online example we can look at.
