Is it possible to use a sprite as a submit button. I already have a button with all the css in place that I use on my site and thought it would be neat if I can use the same for my submit button.
You can style a normal form submit button to use a sprite image, but I
have had mixed results in IE when you do that. The basic style is
something like border:none; text-indent:-1000px; background- image:url(yourSprite.png);.
If you were to use a clear GIF as your submit button, and then style
it with a background image using the sprite technique, you might get
better cross-browser results.
Draw an image box on the page, but don’t import any image into it.
Give it a meaningful name, and use the Item / Extended dialog to give
it a classname like ‘mySubmitButton’. Use the Inspector to make it a
form submit button.
Create a new Tag-only style called .mySubmitButton with the
background-image set to your sprite image.
Create another Tag-only style called .mySubmitButton:hover with the
background-position set to the correct offset for your “over” state.
Preview in a browser. It should work just fine.
Walter thanks, I’m trying the clear GIF route. The button is not visible when I make it a form submit button in the Inspector. When I uncheck the form submit I can see the button and rollover effect though.
Wow, you seem to have found a bug. If you create a blank image, and
then apply the Submit behavior to it in the Inspector, the image
disappears, rather than being turned into input type=“image” as it
should. Any other color than None and you get the expected behavior.
Remove the Submit behavior, and the image also publishes as expected.
The only way around this that I can think of is to create a clear GIF
image of the desired button size outside of Freeway, and import it as
a pass-through.
though.
