[Pro] Sricker
Does anyone know if there is a way to have a Sticker Item inline? I have some Button links that are vertical on the page and when viewing in a smaller window the sticker rides over my footer when scrolling the page.
http://millay.org/direction-hours.php
actionsdev mailing list
What are you hoping to have happen? To make the sticker work at all, it gets pushed up in the z-index stack and made position:fixed, which will make it ride over any other item on the page. Did you want it to stop being stuck at a certain offset from the bottom of the page?
Steepletop Directions & Hours
List Options | FreewayTalk
Maybe that is the best solution. My client doesn’t like how it looks when the sticker goes beyond the footer. I explained why
but they insist I come up with an alternative. Mine would be in line. My page is set up to expand vertically when adding more content.
Can you tell me how to stop the sticker or the offset for the bottom of the page?
Billy
Walt,
Do you have a version of sticker with bottom off set?
No I don’t. I haven’t looked at this yet.
On Jul 23, 2013, at 1:57 PM, “billy kimmel” email@hidden wrote:
Walt,
Can I suggest that you don’t use the sticker action on pages that are not very tall - it really doesn’t add anything to these.
Also for me pages like About Edna St Vincent Millay dont look good at all!
The background is not growing with the text
I’m currently updating the background images to make it lighter. You must have viewed this before I uploaded the change. The sticker is a mater page item because the entire site is built with WebYep CMS. The client can at anytime add more content and then the page(s) are longer. That would not be ideal.
The issue is that sticker is really not optimal for vertical items is you site is inline.
It would be nice to have the option to set bottom off-set in the Sticker Action.
