Lode_Rosel
(Lode Rosel)
November 6, 2014, 9:10am
1
Hello, as you scroll through this site there are different static images in the “transparent” section, is this possible in FW?
Thanks, Lode
Vertoont je kat ongewenst gedrag zoals onzindelijkheid, sproeien, agressie, angst of krabben? We helpen je graag met praktische, permanente en wetenschappelijk onderbouwde oplossingen.
It is. Is called Parallax scrolling and often discussed here (search for it).
It doesn’t work on mobile (just to keep in mind), requires full inline construction method and is dealing with the setting in inspector, pen-tab → background scroll (unchecked) or in other words:
background-attachment: fixed;
Lode_Rosel
(Lode Rosel)
November 6, 2014, 1:09pm
3
Hi Thomas,
Thanks for your swift reply, I’ll look it up.
Bye, Lode
