I’ve just been mucking around with the Sticker action, set up a nice little box with my menus, and a blog feed (in Java in this case) and an Adsense block.
Nice, the ads will be there as my bored visitors start looking for something to click half way down the page.
BUT as soon as the scrolling window gets to the adsense box it just disappears, never to return again until the next page refresh.
Is there a reason for this? Can it be cured?
If I noted that this behaviour is happening on a Blogger page would that explain it?
Can you post a link that shows the problem? It sounds like a JavaScript conflict, but I’m not sure why the effect would appear to work until it reaches that block – usually these sorts of things fail at page load, not later.
For reasons that obviously I can’t explain, I’ve tried to reproduce the problem tonight and can’t!
For the record, tonight I have been adding an Adsense block as a widget through blogger’s system rather than an upload. Whether that has fixed the problem or not is anyone’s guess!
I will post to this thread if it recurs over the next few days.
