I use the Sticker Action to keep the Banner of the site at the top of the browser page.
However if i want to use an Anchor on the page, when i link to it in the Browser the Anchor is positioned behind the Banner, is there any way to overcome this issue please?
You could create a spacer element – an inline DIV that’s as tall as your header – and anchor to that. Just note the Name/ID value when you create the inline box, and manually create the anchor link. (You won’t use the Edit/Anchor tool for this at all, and the anchor won’t show up in the list of anchors for the page.)
Another thing to try is to use the SmoothScroll Action on that page. There is a setting in the Action to adjust the offset from the top of the browser window. That would be an elegant solution to this issue, no need to make any additional inline elements.
