I tried to use Walters sticker action with an Exhibeo 2 Showtime slideshow on the same page. Sticker will not work. If I remove the slideshow, sticker is working.
Any solution ?
Any solution ?
This is (I’m pretty sure) the odd conflict of different JS libraries in use.
I have only one solution:
Avoid using actions which are flagged either as Scripty or FX alongside any other introduced function! Google for “Scroll to fix jQuery” or similar.
