[Pro] stop title code from using "
A very weird ask but I would like to stop freeway converting my " in the title box to " as its messing up my Expression engine code. This is the code I get from freeway when I publish
{exp:weblog:entries limit="1" entry_id="{entry_id}" weblog="lcdwatches" status="open|collection|libraryonly" }Digital Watch Library | {maker} - {modelnumber} | [{watchtype}]{/exp:weblog:entries}
and id like the " to go back to being ". I could change it by hand but as I am constantly making changes t that page id like something more permanent.
thank you in advance for any suggestions
Adam
dynamo mailing list
Hi Adam,
Try this Page Action:
http://actionsforge.com/actions/view/47-dynamic-page-titles
Adam
dynamo mailing list
dynamo mailing list
Excellent Joe thank you, exactly what I was looking for.
thanks
Adam
dynamo mailing list
OK I was wrong that seemed to break it completely. Maybe something with the rest of the code it didnt like.
Adam
dynamo mailing list
Hi
I read that more often, that there is a problem with ampersands in the FW titlebox. But I have used it quite often, never had problem.
I use like this code directly in the titlebox (of inspector) :
{exp:weblog:entries weblog="monumenten" disable="categories|category_fields|member_data|trackbacks" rdf="off" limit="1"}{pagetitle}{/exp:weblog:entries}
which becomes in the Template:
and EE spits out the {pagetitle} of that entree.
dynamo mailing list
excuse me, something wrong with my image…:frowning:
dynamo mailing list
Yes dont know what happened but as soon as I used the dynamic page title everything stopped working at least before all my open status entries showed up. I’ll have a look today and see if I can work out what it is. Can I add the page title manually if I leave the one on the page blank? Or maybe an embed would work.
Adam
dynamo mailing list
If I were you I would create a single entree testpage, with only one DIV with code for a single entree of a particulair weblog (channel) And then write the code for the title in the titlebox of FW. Just to isolate the issue. There might be something else on the page that messes things up.
dynamo mailing list
I worked it out, well not worked it out copied the call from the meta name tag that was written slightly differently using the url_title instead of the entry_id it worked. I dont know whether it was because of that but it works so Im happy. Thanks for your help.
kind regards
Adam
dynamo mailing list
Hi Adam,
Try the Retitle page action (http://www.freewayactions.com/product.php?id=014
). It doesn’t encode the new page title (maybe it should) so your
quotes and ampersands will remain intact.
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
dynamo mailing list
Thanks Tim that seemed to do it. No errors at all.
kind regards
Adam
dynamo mailing list
