I have some basic rollovers on a site I’m working on. Just some images that are sepia-like and change to full color when hovered over.
I used layers and then grouped them and applied the Rollover Action to one of the images. All works fine.
When I alter the images, as in resize or reposition them inside their boxes using the menu item ( as I can’t chose the items directly) sometimes the grouping gets off. It’s like the positioning gets altered and they don;t line up anymore.
This also happens when I copy and paste a group from one page to another.
The fix is to ungroup, then regroup. Then, I have to reposition the group because it’s moved its position.
