Hi all-- I created three separate rollovers each with links to separate websites. They are 80 pixels apart.
Rollover problem: when I rollover each of them, the rollover only works when I rollover on the right portion of the graphic box. (With the exception of Opera where the rollovers work fine)
Hyperlink problem – and this is really weird: when you rollover each item, the links on two of the three change depending on the slightest movement of the mouse. For example, if the mouse is directly over the text it will link incorrectly, if I move the mouse slightly below the text, (but still within the graphic box) and then click, it links to the correct site. There are no overlapping boxes with competing hyperlinks, the closest box with a hyperlink is 80 pixels away.
I’ve deleted all the links and relinked them and it still happens.
Has anyone had similar problems? Thanks for any ideas you may have —
Suzy
