Sorry I didn’t realise that was it down at the bottom.
This is a little tricky without seeing the actual page construction but the Table that holds the pics is 932 wide and the Div ‘BunnMeny’ which contains it is also 932 wide with overflow set to visible.
So you cannot fit a box into one the same size without it overflowing.
Try reducing the width of the Table and see what happens.
