Not sure to explain this. So bear with me.
Example. I have a some lines of text. A list of items. Each item has a bold heading, then a description
ItemA: description
ItemB: description
ItemC: description
I’m trying to style the ItemA bit, as bold, the description as normal text. I can do this easily enough. However, I had a whole page of this, so I was trying to use the Styles option instead. Also, then if I changed my mind, I could alter all of the text by simply tweaking the Style.
So I created a Style for ItemA
Bold, verdana, 12, left allign.
And a 2nd style for the description
Verdana, 11, left allign
So, firstly I select ItemA and apply the style - this for some reason applies the style throughout the whole block of text! Why? If I then try and apply the 2nd style to the description, it applies that style to the whole block of text again, overwriting the first style application.
What is going on? Any ideas?
I can manually go through and apply the correct styles if I use the Inspector pallet, but this is laborious and means I cannot batch change them later. Would be nice to get it working properly.
Is it because all of the text is on the same line with Hard Line Breaks. So that it is confusing Freeway?
Regards Paul
