Looking to create a style to which I can utilize the css3 gradients, I can create a style with background image no problem at all but want to use a style with all of the background images that are required for the css3 gradients : i.e -webkit-background-image -moz-background-image etc but when published freeway only allows one background-image. When reading the code for the css3 gradient it assigns it a # ie item and then the code, is there anyway of implementing this as a style.
Hi Steve,
The trick is to use the extended dialog in the edit styles dialog to add the vendor specific background image styles. You can add them all separately or strung together is they share the same gradient values.
Alternatively you can use the CSS3 Gradients Action - http://actionsforge.com/actions/view/201-css3-gradients
Because CSS “cascades” you can set up all the other attributes for your
style in Freeway Pro - so it will be functional - then add just the
background gradients to the head of the document through the Page > HTML
Markup > Before … be sure to write it properly and enclose it with
the tag. Do that to a Master Page and the style attributes will be
available on every page.
On Sat, Jun 16, 2012 at 3:13 PM, Tim Plumb email@hidden wrote:
Hi Steve,
Have got this working using CSS3 Gradient action, works fine apart from ie9 for some strange reason when you have a corner say 7px you can still see a square corner and the gradient with a rounded corner, i’ve included a background color as a fall back just incase the browser does not support css gradients.
After a bit messing about the only way I can find to get a gradient to work with css3 corners in ie9 is to use a background png of the gradient. Unless someone else knows how
If you can, change the order of the border-radius and the prefixed versions. Always put the non-prefixed version last, as that way when the other browsers catch up to the standard, they will get the correct, non-prefixed version.
On Jun 19, 2012, at 2:05 PM, Steve Mc wrote:
Found a nice easy way which is food for thought and saves a bloat of code for .styles
