[Pro] stylesheets in backdraft
Hi, does anybody know why my stylesheets wouldnt be working correctly within inline elements when using Backdraft (for responsive site) ?
Is this a bug with freeway 6?
its baffling me
regards
Jill
Do you have an example on line somewhere where we can diagnose the issue?
its baffling me
regards
Jill
Hi - no its not live and just putting it together, I could maybe show you whats happening so far if I ftp to my server?
As long as I can click a link here and see it in the browser, that’s where the testing can begin. Remember, not everything that you do with CSS in Freeway will be visible in the Freeway design interface. It’s hit-or-miss sometimes, particularly if you use multiple styles to adjust one element, or use the Extended interface to add special attributes. Previewing in a browser on your Mac should work exactly the same way as viewing it on line from the server, but what you see in Freeway may only be a partial picture.
Hi Walt, the text shows in the correct ‘font’ in freeway but when I test it in the browser it changes!!!
Im sure its something Imdoing wrong rather than a fault of freeway.
Ill get a link for you to see the rough layout
Hi Walt,
please try this link - ive copied all the freeway files of the site in there. Maybe you can see something Ive done wrong, many thanks
CloudApp — Not Found
No, please publish the site as HTML, and post it at a public address. If you want to use a link shortener to mask the URL (so you can take it down without worry before the search robots index it) then please do so. But I’m not going to open a Freeway file to figure out why it doesn’t look great in a browser. I need to see the published HTML for that.
On Mar 24, 2014, at 1:26 PM, Jill Hudson wrote:
Hi Walt,
http://cl.ly/1J2b3f2C3J3U
Hi Jill,
The reason for all this is simple… Freeway Pro generates HTML for the
browser. That HTML tells us a lot about what you’ve done, what FWP has
done, and what browsers will expect from all that. Like an x-ray image.
Looking at your FWP file is a bit like poking at the lumpy surface and
trying to guess what’s underneath. It’s another layer of complexity to wade
through and obscure things.
If you have a publicly accessible server, say for your own website, it’s
worth taking time to create a subdomain where you can lock out the googles
and bots, and create invite-only spaces for sites you are working on. On my
site, it is http://myproof.thebigerns.com
