MattMPA
(Matt Morris)
1
Well, this has me perplexed.
I’m not sure when or how it occurred, but when viewing any page that’s linked to a menu item, the sub-menu items appear when hovered over.
Yet, if I have one of the sub menu pages open, the sub menu item do not appear.
I also notice that the menus change size a little bit.
Glad for any thoughts…
http://winnerfordfleet.com
Jeremy
(Jeremy Hughes)
2
Hi Matt,
I wonder if the submenus are opening behind other content that is on the page - so they can’t be seen.
What you could try doing (if you’re using CSS Menus) is:
- Select the box to which the CSS Menus Action is applied (on a master page)
- Select Extended from the Item menu
- Add the following Name/Value attributes to
position:relative
z-index:99
Jeremy
