Check out this page if you will. When I use the submenus under Product and i hover over the word Raspberry Pi Case, the whole submenu will disappear. It will do a similar thing when on the page 3d logo. Have to be hovering over the word to get this issue.
Freeway Pro 6 and CSS Menus 2.1.13
http://intuitionusa.com/productraspberry.html
Hi Steven,
Your Freeway element m1
(which contains the menu) is on a layer behind
the element which contains the large heading-like text, so the cursor
thinks it’s no longer hovering over the sub-menu which then shuts down. You
can solve this by Extending the <div style>
for m1 with the z-index
property and some ridiculously large value like 99
. This will place the
menu layer over the “heading” and keep the cursor’s attention.
Thanks!!
