Add an Graphic Box where your button should go, and import your button image into it. If you’ve made your button actual size, you can import it as pass-through for ultimate quality. Then, look around in the Inspector (I think maybe on either the first or third tab) for a checkbox labeled Submit. Check this, and give the button a name. It will become a form submit button, but will appear visually unchanged except for a pointer-finger cursor.
On Jan 22, 2013, at 2:00 PM, Carlos Feliciano wrote:
I have a form that I created and I would like to use my own created submit button instead of the standard small submit button. How can this be done.
