Tim,
down to 68 instances of the old SNW- this is crazy.
Do you know the name of the action that will tell me what pages the actions are on that you mentioned?
Barry
6 hours of work and I went through every action in the site pane 1 by one and removed all instances.
It still says 58 in the Edit Actions USED list.
SO frustrating.
not sure what to do now…
Add one in and see what version you get - if the latest then you should be OK.
If not then you will need to keep looking.
all seems ok now
thanks.
