Click once on your outer HTML box, and in the Inspector, click on the up/down arrow icon to the left of the Height field. This will disable the field, and remove the height attribute from that element. This will cause it to shrink-wrap around its contents (so in Freeway you won’t see any appreciable change) but when you view on the browser, only the visible element will be used to calculate the height of your box. The page will no longer have an enormous height attribute and you won’t scroll into empty space.
