Hi,
I just realized that the scroll bar does not show up at all when I just checked my site with my android phone.
All works on computers…
This was made as I inserted a table in an HTML box.
Here is the link…I am going to need to get these to scroll. Ideas??
You want to add a new CSS property to your element where you want the scrolling to happen:
-webkit-overflow-scrolling: touch
To add this, click once on your element (the one you set to Overflow: Scroll or Overflow: Auto in the Inspector) and then open the Item / Extended dialog. Click New, then in the Name field enter -webkit-overflow-scrolling and in the Value field, enter touch. (If you’re viewing this on Mail, ignore the outer back-ticks – they’re there to give the “code format” on the Web view of the list.)
That should do the trick. You can also (on any MobileSafari browser, probably on Chrome or other WebKit browser) use two fingers to scroll any overflowed area, but that’s kind of hidden functionality.
No, you don’t need to add the colon, Freeway will do that for you. I forgot to mention, you have to select the DIV STYLE segment of the Extended dialog, so maybe you added it to the DIV tab. If you did, remove it from there and create it in the DIV STYLE tab of the Extended dialog.
I moved what you sent over to Div STYLE. I reuploaded. Tried on phone and no luck.
it’s quiet all right - a very low priority.
Appreciate it.
My bigger concern (and I am going to be sending you a screencast) has to do with uploading and “dots” on 8 pages. Softpress wants me to send them the entire document with all files but I am trying to avoid that for now.
As I said to you before Barry the best/easiest way to diagnose this is from the whole file.
I know Dave but the process Softpress wants me to go through to get it to them is so much and it just seems like something that can be fixed easier since we know all we did to this long project.
I did this test and I thought this would tell me something but no great luck…
I made a new master 2
I made a brand new page and worked it off of master 2 (becuse I thought all this was b/c of master 1)
typed a few words on new page (master 2) and previewed and 8 pages got dots again and had to be uploaded.
I thought this would tell me something.
Obviously you can see I am trying to find it and avoid the whole sending file thing.
I guess me sending a screncast of my FW problem is like sending a video of a car driving trying to find its automotive problem. One really needs to look under the hood.
people at Softpress wanted me to do this first… is it necessary before I send to you??
“First thing to do is to go to Edit>Resources and click on the Resample All button. Once that’s finished, look through the list of resources to check that they all have a status of OK - if any have a status of Missing, select them one at a time, click on Edit, click on Locate then relink to the original resource file.”
