Is is possible to have a new, smaller window pop up over the existing window, on click.
2 actions - Link to new window or Pic to new window
In the action parameters you can set what size your window should be, whether it should have Toolbar, Scrollbar etc
Is it possible to have that from a e-buy button? So make the e-buy button go to a new window but that window is smaller, Via the target section in the action settings.
What content do you want in the smaller window?
Bear in mind that this parameter of the E-buy form action is really designed to aid where the cart page is displayed - the link to the cart is hard wired so that is where you will be taken.
There may be settings in Mal’s that allow you to display the cart contents on your page if that is what you are trying to do.
Also there is this thread on the subject http://freewaytalk.net/thread/view/59154
Do you happen to know where those settings are in Mal’s?
Having delved a bit deeper I don’t think they are there.
Have a look at http://www.malsforms.com/display-cart.html
This in conjunction with an iFrame on your page to display the cart should sort you out.
The iFrame url should be
http://ww?.aitsafe.com/cf/review.cfm?userid=youridhere
An example: http://www.deltadesign.co/andends/registeragain.html?
If you need some help putting this together then I can send you a file.
