Can someone help me with the following problem: I have a image in a text. The text is interrupted. I want the text flows beside the image.
I use Pro 6
Thanks in advance. Kees Huijsen
Can you show us an online example.
If you want to add an image into a run of text then get a flashing cursor at the start of your line/paragraph and use insert graphic item (and import your graphic into the container)
Now look in the inspector and with the graphic selected look for the options for Align ie Top, Text Top, Super, Middle etc. to set its relative position.
It works. Thanks David.
