[Pro] Template for artists work
D… it seems to work fine in Safari but in FF it splits the title into 2 lines
Why?
FIXED it… Just dragged the html ‘box’ wider. Seems to work.
a
Just all the other points to address on all the other pages.
D Got most of it corrected; albeit I left the “text too close to container” and name under image on Contact page as is as a matter of choice.
Now the way it responds in FF and Safari seems okay at all widths from here.
I did NOT find why the CSS menu is different for some of the ‘items’ -( It may be ‘how’ the item was ‘created’.} The ones with difficulty in placement and use always have the CSS circle in the upper left corner of the Inspector, rather than down 5 or 6 lines - and the items in the inspector are slightly different.
Any clues?
Thanks for the help and patience
Ann
Much improved Ann however there are are still a few areas that could do with some improvement.
There appears to be no contact email address on the Contact page - deliberate or an oversight? Most people these days will dash off an email before calling a phone#.
Image quality - still quite a few images that need improvement. Particularly - Katreena with dog, Inga with Alessandra (seated), every image on MoreArt, Angel on my shoulders.
Not quite sure why there are 2 different text styles on the Catalog page?
The difference is likely to be that some items are based on a Master item and some not. ie if it appears on the Master then the CSS checkbox appears down 5 or 6 lines.
Thanks D… you have a sharp (good) eye.
Yes those images need improvement.
The site is still in development. Little in fixed. Catalog and MoreArt page images and text are place holders. Nothing fixed.
Ka with dog image is the best PSE could accomplish with the poor image received so it’s just to show how it can appear.
Your help with flow and flexible, etc is much appreciated as well as the suggestions and comments.
Ann
