I used an existing website which I had made using FWPro as a template to build another site. I saved all the files and the template in a separate folder and all the files connected with each one are uploaded to separate folders on the server, but now both sites (the original AND the copy) give me a warning when I upload, which says “One or more HTML files which do not belong to this site will be overwritten”
Did you change the path to the Site Folder (Document Setup dialog) when you made your new site?
