[Pro] text blocks
Hi,
I’m having a hard time constraining my text blocks. I would like text blocks to automatically reflow within a certain horizontal limit that I stipulate (580 px, for example). To achieve this, I set the text block to align to the left, the width to be fixed (%), the min. size to be 20%, and the max. size to be 580 px. The text is set to helvetica neue light, size small. I’ve noticed that even with the same parameters, different text blocks behave differently. Some behave as expected, and others exceed the max. width when the loaded browser window is enlarged in the horizontal direction. Should I be using different parameters?
It is ever so hard to envision the problem in the abstract - I will say
that if you are using % widths, it’s a good idea to understand % of what?
The browser window?
Percentage widths are always in relation to a container of some sort. If
you wish to restrict them, use max-width (1) as well or (2) instead. That
way, you are saying - for example - this container will be 80% the width of
it’s parent, but never exceed the maximum width of 640px. Or by itself, you
are saying that it will be as wide as possible but not exceeding the
max-width limit.
On Tue, Jan 21, 2014 at 1:26 AM, Erik M email@hidden wrote:
Hi,
Also bear in mind that unless you are using one of the WebFont embedding techniques your visitors will only see helvetica neue light if that font is installed on their system - not likely for most users.
The ‘small’ sizing (relative) is also variable across systems and for consistency you would be better defining your font using a px size.
