[Pro] Text Editor
Hi,
Can anyone recommend a text editor which won’t fall over when I throw a large file at it?
I mostly use Smultron, which I like, but it falls over every time I throw an e.g. 10mb mysql backup file at it.
I don’t need high end features, simplicity and clarity is more important.
Hugh
BBEdit is a great text editor although TextWrangler might be able to do it, I know BBEdit definitely can.
Both products are from the same developer:
http://www.barebones.com/products/
HTH
On 09 Jan 2015, at 3:23 pm, hugh email@hidden wrote:
Hi,
Hugh
List Options | FreewayTalk
thanks, Mike!
Already have Wrangler somewhere…never liked it’s look, though, everything looks…err, spidery!! Smultron was big and bold.
Haven’t used BBEdit for years…maybe I’ll download and try that.
cheers
Brackets http://brackets.io is very nice and free. I’ve tried it with files of ~10k lines without problem. Of course Sublime and TextMate are capable, too.
https://xiiro.com
thanks, Todd.
Do you think that will work on SnowLeopard?..
Brackets? Hmmm, I would be surprised if it does. But I also don’t know what the system requirements are either.
https://xiiro.com
thanks, Todd.
BBEdit (or its free cousin TextWrangler) can deal with files of hundreds of megabytes size on a suitably RAM-enabled Mac. I routinely use it to search through server log files and database dumps. BBEdit is the oldest continuously-developed Mac application, has been for several years now. There is a version that will run on your Mac. Full stop. I am sure that if you find a Mac Plus in your attic, and can convince someone to (postal) mail you a floppy disk with the app on it, BBEdit 1.0 will run there, too.
https://xiiro.com
thanks, Todd.
