Hi chaps … if you look carefully at this page the text fades when the images slide in … well it does in my browser anyway … any thoughts please ?
Roger
http://www.keithbryantjewellery.co.uk
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
The body copy stays as it should be, but the menu text does a quick fade on mine.
Roger
Likes: 1 ❤
This is a known issue with webkit browsers - this piece gives some insight and some potential cures but it is all to do with text renderingwhen there are animations or transforms on your page.
There are many articles on the subject - and quite a few threads here on FWT.
Once you have decided which route you wish to go down we can help you try out a fix.
D avid
Likes: 1 ❤
I’ll dig through those thanks Dave and Trev … I’ll let you know.
Roger
Likes: 1 ❤
This seems to have sorted it … I think :
Likes: 1 ❤
Thank you bigerns
Roger
Likes: 1 ❤
