[Pro] text field and mobile safari
hi everyone
trying to simulate a search field similar to (yes safari search) created a html element with css3 corners and with text field and search button all works great in the browsers I want but mobile safari seems to increase the size of the text field in relation to the html box with a shadow effect on the top of the text field. Is there anyway of restricting this to get rid of the text box shadow effect on the text field. Already tried form element styler and form fix but now a bit stuck.
Any help would be much appreciated
tutorials mailing list
Maybe it is your approach that is introducing some styling peculiarity.,
Walter outlined a method to do exactly this some time ago in FWT - have a look through the forum for Safari Search
You should find this thread http://freewaytalk.net/thread/view/61133#m_61148 amongst others.
You will also find this link Safari Search which leads to an example page that uses an action created by Tim
