[Pro] Text flow action
I want to use the text flow action on a site but it does not appear in the actions menu even though it is loaded in Freeway.
Am I missing something???
Most actions are context sensitive ie you wont get the option to add the action unless you have selected the correct type of item/container. May have to be a layer? Dont have it so can only guess.
