The only difference will be to those who try to help you. Browsers
don’t care (much) about whitespace in code. People find it very hard
to read code without some structure to make the relationships easier
to see.
On Jan 12, 2010, at 9:12 AM, Cos wrote:
Have reset the HTML code to ‘More readable’ and re-made the page
which has made no difference!
Try drawing a single html box the size of your right hand column. Draw
it on the pasteboard next to the page so you can do the next trick.
One at a time, click once on each element in the right column so it’s
selected (handles showing on all sides/corners) and cut to the
clipboard. Then double-click inside your new HTML box so you see a
flashing text cursor in it and paste. Repeat until all elements have
been moved into this new box. Finally, set the new box to have no
height (click on the icon to the left of the height box in the
Inspector) and move it into position on your page. If your boxes crash
into each other vertically, select each one in turn and apply some
bottom margin. You might also go through all of these inline boxes and
remove their height as well. The final result will scale the boxes
along with the text size.
iPhone does some clever things to get the text size up above the
“where’s my glasses” zone, and you’re seeing the dark side of that
noble effort.
It is your page construction - layered HTML boxes containing quite a lot of text. As the text size increases the containers and overlap the other HTML containers.
If you leave a bit more space between them it will accommodate a bit of text growth.
