carla
December 26, 2012, 3:49pm
#1
Merry Christmas to all!!!
I have a small thing I would like to achieve here. Normally fairly easy but as this is Text Rollover action, I am finding it a difficulty.
I have a text rollover attached to text and a target /show layer on another list
I put color states in the inspector palette as I do for these types but what does not work is the active state on the text rollover.
if anyone has a solution it would be great.
C
The active state is the state of the link the moment it is clicked - no click - no active state.
carla
December 27, 2012, 12:19am
#3
Merry Christmas Teach!!!
right I get that.
so is there no way to keep the text highlighted when target is activated??
Hope your holidays are great
C
Can you show me an example of what you have/what you want to happen. But if this is to activate a target show/hide then it is a bit more complicated and the text rollover action may not be the way to go.
carla
December 27, 2012, 12:34am
#5
yes I will send you a link
I am now trying a regular gif text rollover but having a time of that too as there is no state for that. strange
Correct
carla
December 27, 2012, 12:46am
#7
correct… so there is no way to do this.
Yes - but not using the Text Rollover action
Instead create your rollovers using the method outlined here - http://www.deltadesign.co/fw_examples/rollover.html
Then you can set the rollover to have a sticky state after it has been rolled over and then the state will change when the next one is triggered.
