I’ve got a string of text, six characters, that I’m building a logo with. Two fonts, two colors, and some variations on kerning, baseline and font size.
When I apply a shadow to it, the text becomes uneditable, and selecting it selects a little dot to the lower left of the text. If I remove the shadow from that bogus selection, then I can edit again.
Can´t confirm.
To edit the text just hit “T” and make further adjustments. To leave text edit mode hit “return” key at the num pad or select any other tool.
So far, I’m having better luck using the Effects dialog, for which thanks.
The above is repeatable if I select the text (that is, all the characters) and apply a shadow via the Fonts dialog (cmd-T).
OTOH, via the Effects dialog, the Drop Shadow option is grayed out if I have characters selected, and is available only if I select the entire object (not in text mode).
So I think I have a workaround (need to play around some more), but a) there’s a bug and b) navigating to the Effects version of Drop Shadow is far from intuitive.
I´m pretty sure it´s not a bug. The effects/core image/quartz engine accepts only objects. I´m not sure what you´re after. If you want different shadows per key you have to choose a different approach: Copy&paste a key, set blur/size/place and color send it backwards. Or use effects per single key text.
I’ll post some screenshots later. We may mean different things by “object” here; I’m talking about the difference between selecting the text box as a whole and selecting characters within the text box.
