Can anyone help me with text size in html, when i preview or publish pages with a reasonable amount of text the text seems to squash close together leaving a lot of space at the bottom of the item’s frame.
The text in the main text box fills the frame in the layout page but as you can probably see it shuffles up after publish or in preview.
There is no leading set and teh text is set at 14px. When i look at the freeway templates this problem does not occur, so it must something i am doing or a setting - i couldnt find anything different though when i cross-checked between the template and my page though?
I think that your biggest problem on this page is that you are using HelveticaNeue-Light - a font that is not going to be available to most of your viewers.
Thanks David, appreciate it. The problem occurs with other fonts too so i don think that is the main problem, the line height may be the issue, where do i adjust that?
