Hi all, I’m new to this forum and freeway 5.5 pro I am looking for advice on adding a text window with a side bar like the one in this link. www.estetics.co.uk
Thanking in advance for any help
Hi David, the example that you added does not show what I need for some reason? Any way what I what to do is add a text window with a scroll bar. So that no matter how much text is added the physical size of the text widow stays the same but you can scroll up and down to read the text within, just the same as a side bar on a page! Hope this makes sence?
I see it on the example page you posted now but I had to increase the text size in my browser.
The reason they have done it this way is because the background image is a fixed size so cant expand to fit more content or a larger text size.
You can quite easily construct a page in FW that would look the same and have text areas that would expand if your text size was greater or more of it.
BTW your eyesight must be worse than mine if it was showing the scroll bar.
The only way to do this (scroll one direction only) is to use the
Extended dialog. First, remove the overflow setting you added with the
Inspector (change it back to the default of "Visible). Then from the
main menu choose Item / Extended, and make sure that the DIV Style tab
is selected. Then click new, and enter the following name/value pair:
Value: auto
This will cause the scroll bar to appear only if it’s needed and then
only on the y-axis (vertical scroll).
On Dec 15, 2010, at 5:38 AM, MarkSmith wrote:
The result I have is that the box is showing an empty horizontal
scroll bar at the bottom.
Value: auto
