rakeljuice
(rakeljuice)
1
Hello. Ive set a webyep system in a site, and when I edit a text, and press return, in the edit box it looks ok, like
line1
line2
but in the page it is like this:
line1
line2
and if I press shift return is happens the same.
Any idea? Thanks a lot
dynamo mailing list
rakeljuice
(rakeljuice)
2
well, Ive made it from a windows pc, and it works. arrggg I cant manage with the rich text format in macintosh pc …
dynamo mailing list
Hi Rakel
If you are using TinyMCE as your richtext editor then try editing the text in Firefox rather than Safari
for some reason TinyMCE and Safari don’t always work perfectly together, so its sometimes easier to use Firefox.
saludos
Max
dynamo mailing list
