[Pro] Thanks!
The new version of Freeway Pro appears to have solved my problem about windows (Inspector, Actions etc) not opening when Freeway restarts. They all open now! Thank you!
Paul
Sorry, my mistake! The problem is the same as before, so I’ll have to make this ‘Unthanks’!!
Paul
The answer, as always, is to quit Freeway in the state you wish to find it when you next open it. If you brink Freeway to front, and quit it manually, you will find it with its palettes restored when you next open it. But if you quit it without bringing it to front, you will find the palettes hidden, just as they were when the application was quit (the palettes only show while the app is running).
Paul
Sorry, meant to say “while the app is front-most
Yes Walter, I understand this. I just wish it were otherwise!!
Paul
Paul,
Are you aware that command-shift-h will toggle all open pallets? I stumbled across this by accident the other day, but now I use it all the time! Hope this helps…
Hello Doty. Thanks for that – it could be useful – but I don’t think it resolves the issue I raised.
Paul
Actually, that’s a fine suggestion Doty and does solve the problem. Paul, all you need to do is press that shortcut (Command-Shift-H) after opening Freeway and the palettes will appear where they were before you quit.
I have just checked your suggestion Doty after shutdown, and yes, it works well. Thank you very much. I’ll have to remember ‘Command Shifty Henry!’ Automatic would still be better … !
Paul
I work from a laptop all the time. In other words, a small screen. I use this shortcut numerous times a day to temporarily hide the pallets so I can see something that is on my desktop. You can train yourself to remember Command Shifty Henry!
Automatic would still be better … ! Paul
Maybe for you Paul - but for others not!
New to Freeway. Any help greatly appreciated. When developing QR codes to re-direct to a website. First, does Freeway have specific tools for creating iPhone/iPad sites? Two, do you have to create two sites? Mobile and traditional? Is there a way to have the traditional website converted, on the fly (?), to a mobile site or re-direct to a mobile site? Thanks again for the help!!!
Well Dave, I guess it could be an option?!!
Paul
