The best way to get help is to give help. What help can you give?
- Describe your problem as simply and plainly as possible.
- Use images and links to examples of what you are trying to achieve or avoid whenever possible.
- Indicate whether you are using Freeway Pro or Freeway Express.
- IMPORTANT: try to include links to your page(s) that are misbehaving. Freeway Pro generates page code; Browsers read page code. More often than not, we will need to read your page code to understand what is wrong.
